We’re encountering an authentication issue with Creo View in our shop floor kiosk setup and would appreciate any insights or suggestions. The below issue is observed after configuring Windchill with SSO
Environment:
Setup Overview:
Observed Behavior: It appears that Creo View is attempting to authenticate using the Windows login (saaccount) rather than the Windchill credentials used in the browser session. Since (saaccount) is not a registered Windchill user, the authentication fails.
Has anyone faced a similar issue in a shared kiosk environment? Any guidance on how to configure Creo View to use the Windchill session or prompt for credentials instead of defaulting to the Windows login would be greatly appreciated.
Hi @VS_11517676
Thank you for your question.
Best regards,
