Is there any method for creating multiple planar sections when viewing .pvz files? Are there any plans to create other, non-planar types of sections?
If your PVZ generated from Creo Parametric then you can publish both Planar and Offset Cross sections. And same sections can be viewed in Creo View (Sectioning Tab >> Present Section)
In Creo View you can either create a planar section or Quarter Cut section which uses two plans for sectioning.
Thanks for the reply!
I'll have to look into pushing sections from parametric, but that obviously only helps when you have access to the source .asm/.prt
The Quarter Cut section is great, but from what I can tell you can only remove a quarter with it instead of isolating that quarter or adding additional planar sections to view isolated volumes of your Creo View model.
