Is there a way to show offset lines in exploded views in Creo View 5.1? The Exploded view seems to publish fine, but the offset lines do not show up even when all construction geometry features are checked in the config settings (see below).
The functionality needs Enhancement in Creo View Adapter & Creo Parametric. Work is under construction and soon functional compatibility will be defined.
Is this function available now? I can't show my offset lines on the PVZ
Has this functionality been implemented yet?
Yes, now you can see the offset lines, we use creo 10 at work and they now show on the PVZ
