Creo illustrate custome line thickness
Stephen_DeLeon
9-Granite
I just wanted to ask if there is a way that I can adjust my line thickness while using the HLR mode? let's say there are some parts in the model where I want thicker lines and other parts of the model with thinner lines.
Thank you
Adjusting line weights per part is only possible in 2D figures.
For 3D figures the thick & thin line weights are set for the figure only.
I would suggest creating a product idea is this capability is important.
Creo View / Illustrate / Schematics Ideas - PTC Community
