Hi All,
In CreoView when I open a new instance to view a model it will set the perspective mode active view FOV to 60 when the default is set to 110.
Anyone have any idea how to force CreoView to set the FOV without needing to manually change it every time.
Screenshots attached of options menu.
Cheers,
Reece C
Hi Reece,
This appears to either be a bug or a minor issue setting the default. I've confirmed that in Creo View 8.0, I'm not seeing this behavior and the default is honored.
I would suggest opening up an call with Technical Support to take a closer look.
Odd thing is this persists across every version of Creo View we use here.
The screen shots I attached were from Creo View 8.0, although this is the first time it has saved in the defaults tab of the options.
