We work with Inventor for 3D modelling and when these models are viewed in CreoView Lite, it opens upside down by default. Which setting do I need to change in CreoView to open models with the Z-axis pointing upwards?
Discussion - "Creo View: Rotate view about X/Y/Z axis": https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-View-Rotate-view-about-X-Y-Z-axis/td-p/640435
Hi, thank you for your reply. I think this indeed solves my problem. However, modifying the orientations is not available in CreoView Lite, but only in CreoView Mcad.
