The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Error: A design does not exist at specified location
CP_8840360
7-Bedrock
I am using Creo Schematics 4.0 M010
Software gives an error when trying to open the attached drawing: A design does not exist at specified location
Here are the errors that I faced
Thanks. I opened also C15792003.
5 REPLIES 5
Usually this is because of corrupt data. To have a look at it and probably correct them, a case needs to be opened at PTC. Link: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
I opened C15798014. You will be contacted by PTC. You may accept this as solution for this community thread.
hhiller
(To:hhiller)
Thanks. I closed  C15798014 as duplicate to C15792003.Please close the thread by accepting solution to open a case.
hhiller
(To:hhiller)
