Exporting sections with hatched section faces to vector PDF
VecTor
With Creo Illustrate, is it possible to export sections with hatched section faces as a vectorial PDF, including the hatching?
In other words, in the exported PDF all lines, including the hatching, should be vector lines, not bitmaps?
2 REPLIES 2
Hatching on section cuts is currently not possible in Creo Illustrate.
I would suggest voting on the idea below as we do consider the most popular ideas when considering future enhancements.
Creo Illustrate: Hatch lines on cutting planes - PTC Community
VecTor
(To:agarland)
Thank you. Does this mean that this is currently only possible with Creo Parametric?
