The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I have a full license the entire suite, all software work well. I think when I start schematics 1.0 says: unable to obtain license for Creo schematics. I just think schematics 3.0 and Schematics 2.0 works, but I need the 1.0.
above do all procedemientoras to start Schem 2.0. Now me so with Schem 1.0. (try the same procedure you explain me, but this time it turned out)
Ronny,
License for Creo Schematics 2.0/3.0 is not downward compatible to run older versions. Check https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS59742
Ronny,
