How do I change all step descriptions at once at Creo Illustrate
JG_8568288
11-Garnet
 as per default, Creo Illustrate names the steps within a sequence "step 1", "step 2" etc. If I insert a new step afterwards at the beginning, it will be called after the last step created, e.g. "step 50", which doesn't make much sense. I now need to rename all 50 steps manually which takes a lot of time.
Is there a way to achieve that Illustrate renames all steps in order without "step" - just "1" "2" "3"?
My version is Creo Illustrate 9.0
Unfortunately there is currently no way to rename all steps in one go, it does have to be done one at a time.
I think this would be a great candidate for a new idea. 🙂
Creo View / Illustrate / Schematics Ideas - PTC Community
2 REPLIES 2
