I would like to understand if we can add the specific standard electrical libraries from an external sources? If so what is the procedure? Kindy help.
Naresh
Similar question - "Import component library in schematics": https://community.ptc.com/t5/3D-Part-Assembly-Design/Import-component-library-in-schematics/td-p/169364
Hi @VP_9467744,
Anurag
