How to Create Illustrations in different language in Creo Illustrate
Aditya1702
Hi Everyone,
I want to create illustrations in creo illustrate in  some other language.
Can someone guide me how to  go about it . I am using Creo Illustrate  10.1
Thanks in advance.
Aditya Gupta
Yes, it is a manual process to export and import the xlif files unless you are using Windchill.
For Windchill there is the ability to have an updated xlif file automatically applied to the c3di.
About Managing Localized Text with Windchill (ptc.com)
Regards
Adrian
9 REPLIES 9
Article - "Creo View & Creo Illustrate: How to override the default User Interface language set on a Windows machine": https://www.ptc.com/en/support/article/CS96862
Hi @Aditya1702,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
Community Moderator
Catalina
PTC Community Moderator
Aditya1702
(To:Catalina)
Hi @Catalina ,
We have raised a case for the same since we wanted to create annotations in different languages & not change the UI language.
I will update once we have a solution.
Thanks & Best Regards,
Aditya Gupta
Creo Illustrate does have a localization feature for notes in figures.
About Localizing Text (ptc.com)
This allows you to export an xlif file for processing in a external translation tool before importing the translated xlif back into illustrate.
Aditya1702
(To:agarland)
Hi @agarland ,
Thanks for your response.
Its a manual process right?
First we have to export .xlff file and then manually translate all the text and then again import the file correct?
Correct me if I am wrong also, can this process be made auto?
Aditya Gupta
Regards
Adrian
Aditya1702
(To:agarland)
Hi @agarland ,
Can you please tell me about which external tools to used  for translation.
Thanks in advance.
Aditya Gupta
I can't recommend a tool I'm afraid although I believe there are many translation tools available that handle xlif files.
Regards
Adrian
If you want your illustration text to make sense in multiple languages, my advice is to use a formal translation vendor. Trying to do automated "machine" translation, especially with highly technical content, is likely to produce some questionable translations, possibly leading to errors and confusion on the user's part.
