How to change the sequence or step speed(fps) in Creo Illustrate for publishing in Vuforia Studio?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Dear PTC community,
Please, advise how I can change the fps speed for the already-done sequence. My current sequence is too slow and I want it to play 2xfaster.
I see that there is an option to play it faster within the Creo Illustrate:
I know that I can manually shrink the length of each step or if necessary shrink each effect duration: it takes too long for 10 sequences.(20 steps each).
But I don't know how to set 2x speed for fps for publishing pvz and c3di Vuforia Studio. Please advise any solution,
- Labels:
Creo Illustrate
- Tags:
- fps
- Keyframe Editor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The option you have shown is simply a playback speed and does not affect the published output.
The only way to slow down the playback in the published files is to stretch the step in the timeline as you have mentioned.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@agarland thank you for your response.
but 😢 still have hope ...
Probably there is some Java script way in Vuforia Studio to play steps faster/slower.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Nope.
Like Adrian said, if you want the sequence to go faster, you modify the sequence (in Illustrate) to make it run faster.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
the reason for this is simple - the definition IS the definition. In the same way that you cannot change the shape of a part, you cannot change the order or the timing of the sequence.
