Illustrate Interrupted or collapsed view / partial view
Ramon_Bohne
I have two question about creating views in Creo Illustrate.
1.) Is it possible to create a kind of interrupted or collapsed view (or what I shou call it) to push large parts together (example: View1 and View2)?
2.) Is it possible to display only a part of a view, so that it is still possible to place position numbers (callouts) on the left and right (example: View3 and View4)?
Thanks and greetings
Ramon Bean
Ramon_Bohne
(To:agarland)
Hello Adrian,
yes, that was very helpful. Thank you very much.
With kind regards
Ramon
6 REPLIES 6
For question 1, this would have to be done manually be creating a 2D figure and then editing the content to remove the unwanted section.
The issue would be that you couldn't use a background image for the shaded effect.
For question 2, this would depend on what the final deliverable is.  If it's a 2D formal Svg or cgm etc then you should be able to use the page to crop what is included, ie' remove anything outside the page.
I think it could be a little tricky to achieve either of these results but using the suggestions above you may be able to get close.
Ramon_Bohne
(To:agarland)
In the end, I always need a simple image file as *.bmp or *.jpg.
And yes, if it doesn't work in Creo-Illustrate, you can of course do it all quite easily with a graphics/painting program.
But first I want (should I) check if it is possible with Creo-Illustrate only.
And yes, I want to have colored and shaded images.
So the question is: Is there an easy way with Creo-Illustrate to create the image files as desired, or should I better edit and finalize the finished image with a graphics/painting tool?
Best regards
Ramon
Hi Ramon,
So there is a way to create a figure that is very close to what you are looking for using the insets and a 2D figure.
Here's the basic steps:
  1. Create a 3D figure showing the assembly in the correct orientation
  2. Add two insets that contain the details of each end of the assembly (See image 1 below)
  3. Turn off the borders for both insets
  4. Move the main view of the assembly outside the page (again see image 1)
  5. Now create a 2D figure from this 3D figure
  6. Hide the two inset views and select/delete the unwanted main view
  7. Unhide the insets and manually add the curved lines to indicate the truncated view (Image 2 shows a very rough example)
Hopefully that gives you enough detail to get the view you are looking for.
Image 1Image 1
Image 2Image 2
Ramon_Bohne
(To:agarland)
Hello agarland,
thank you very much, that looks good and works almost fine.
One more question: how do I get the shaded images into the 2d figure?
Best regards
Ramon
Good to hear this works for you. 😊
To include a shaded image you need to check the "Include shaded image" option in the 2D figure settings.
When creating the 2D figure select "2D Figure settings" option:
2D figure settings2D figure settings
In the dialog check the "Include shaded image" option and set the required resolution:
Include shaded imageInclude shaded image
This can also be done for existing 2D figure via the "Figure Settings" button in the Figure ribbon:
Figure settings buttonFigure settings button
Might be worth checking your image quality setting found in Options>Global>Model, to be sure the output is of a good enough quality.
Image quality settingImage quality setting
This will hopefully get the results you're after.
Adrian
Ramon_Bohne
(To:agarland)
Hello Adrian,
With kind regards
Ramon
