Hello
I want to know about the compatibility of illustrate and creo version.
For example, would it be a problem to work on illustrate 9.1 with the results you worked on creo 8.0 version?
I would appreciate it if you could give me a document or answer related to this.
Thank you.
This information is included in the PTC Technical Graphics Compendium
There is a table "Creo Illustrate Supported Import File Types" on page 7 that specified the supported versions of Creo Parametric.
Like Creo View, Creo Illustrate is backwardly compatible with several versions of Creo Parametric.
Article - "Where to find the Software Compatibility Matrix for a specific release and datecode of a PTC Product": https://www.ptc.com/en/support/article/CS99145
