Normally in creo view once you set your default printer, then creo view remembers each time your print so you don't have to keep selecting. A user is selecting his default printer, but when trying to print in creoview it is showing another printer as default. I assumed he was clearing cache on exiting IE but that was not the case. Has anybody else experienced this issue?
