I am using Creo Direct N/A N/A
Hi Support Team
We bought the Creo and try to install. First I already input the HOST ID and get license file. and try to Add my staff PC it shoe "Not Suitable"
May I know what should I do ?
Here are the errors that I faced
"Not Suitable"
This is the user community, not PTC support. You may get some help but you would be much better off asking PTC support for help.
https://www.ptc.com/en/support
Hi @IW_9975185
As you are installing Creo , may be for the first time, and you alredy get your license file with the hostID , if your license is a floatting license, you need to install the License server application.
Run install_license_server.exe under Creo 8.0 installation media folder to install license server .
If this help to solve your issue , please mark this post as solution accepted.
BR
Jean Claude
Hi @IW_9975185,
As you install Creo 7.0 you need to:
Run install_license_server.exe under Creo 7.0 installation media folder.
Jean Claude
