IsoDraw image transparency problem
JB99
I am working with TIF files and I need to turn image transparency on. I have created a macro that does this and it seems to work fine. My problem is when I save/export the file out with the transparency on everything appears fine. When I open the file again the transparency is turned off. I have tried not using the macro and manually changing the image transparency to on and then save/export the file with the same result, when I open the file again the transparency is off.
Does anyone know what might be causing this and how I can fix the problem?
I am using IsoDraw 7.1 F000
Thank You for any and all help,
Keith Howard
3 REPLIES 3
HI Jessica,
Can you upload the Macros you are using to make the TIFF images transperent?
mano
(To:JB99)
Transperancy in IsoDraw? That is new to me
aselvaraj
7-Bedrock
(To:JB99)
Transparency in Isodraw? do you mean the transparency in layer tab? the gray scale one?
