.MSI File for Croe View
Brn_The_Admin
I'm working with my IT dept to try and install Creo View en masse and they are asking for a .msi file. Is there a way too get one? The default download on PTC Support is just the .exe in a ZIP.
Has anyone done a mass install of Creo View? Any recommendations for tackling this?
Trying to install V11.1
In the zip package you should see a folder called "pview", inside is the MSI file. There is also a section in the install guide on using the silent installer (MSI) process.
Let me know if you need anything else.
