When we print AutoCAD drawings from Creo View, it spools for a long time before printing (30 sec - 1 minute). Does anyone know how to speed it up?
Creo View version? What printer are you using (you are trying to printt "DWG" or "DXF")? Also, you can try to use Autodesk "DWG TrueView" viewer for printing and then compare the speed of printing:
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=9078813
http://download.autodesk.com/esd/dwgtrueview/2013/SetupDWGTrueView2013_32bit.exe
