Remove Root object from Save As PVZ
al3
6-Contributor
6-Contributor
I am looking to see if its possible to delete this "Root" designation in the PVZ. Highlighted in picture below.
BillRyan
(To:al3)
My structure in the save as file matches the structure from the source file.  My process for creating the PVZ from Creo View MCAD version is to
1) select all geometry and
2) use "Save selected as PVZ"
al3
6-Contributor
6-Contributor
(To:BillRyan)
I was combining PVZs together to edit the structure. The "Root" designation comes up in that scenario. I don't think it can be removed but wanted to see if someone knew.
