.SEC files not opening
JZ_9932703
2-Explorer
Creo View Express 7.1 will not open any of my .sec files.
5 REPLIES 5
BenLoosli
(To:JZ_9932703)
Why are you trying to open a section file in CreoView Express.
I do not see where .sec files are supported in CV.
That is the program I was told to use. What program should I be using?
Attached is a snip of the program showing that it can support .sec files.
BenLoosli
(To:JZ_9932703)
Your image shows Creo Parametric supporting .sec files, not Creo View.
Creo Parametric will open .sec files.
What program are you actually using?
I am using Creo View Express 7.1.
