Unable to open CAD Model with .sldasm format in Creo Illustrate
oparfon
Good day everyone,
we trying to open the file with format .sldasm in Creo Illustrate but unfortunately are not able to see it during the import.
Based on this PTC Help Center . sldasm should be supported format. Are we missing something here?
The version of creo: 8.1
And solidworks
 The model properties:
Best Regards
Olena
Hi Olena,
It looks like you are running Creo Illustrate Standard which does not support the import of Solidworks files.
You would need a Professional license to enable those formats.
Adrian
VladimirN
24-Ruby II
(To:oparfon)
 Hi Olena,
What version of Creo Illustrate and SOLIDWORKS are you using?
P.S. @agarland
oparfon
(To:VladimirN)
I added this info to the message
Hi Olena,
Adrian
Thanks, Adrian!
oparfon
(To:VladimirN)
Thank you!
