Would it be possible to open a 3D pdf file saved as a pdf in Creo Parametric 7.0?
pobsd
I have a 3D PDF that I received from the supplier. Is there any way that I can open it in Creo Parametric, similar to the Step file. Would it be possible to save that file in Creo Parametric?
VladimirN
(To:pobsd)
VladimirN
(To:pobsd)
anursingh
Moderator
(To:pobsd)
Hi @pobsd,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
