different parts same animation
GianVal
I'd like to know if there is the possibility to create a "parametric animation" in which I can change the components of a model but keep the same animation sequence.
Let me explain: in this way I could "prepare" the animation even without the final version of some models.
is this feasible?
remy
(To:GianVal)
You need to create an animation in an assembly with components that are likely to be replaced.
This type of a project is the aim of interchange assemblies: https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/#page/fundamentals/program/about_replacing_components_in_assembly_designs.html#
You may give it a try.
