how to open a door at the hinges?
ptc-804648
Hello all - I started 7 years ago with ProductView 6 and then version 8 and now I try to get along with CreoIllustrate.
My actual problem is: how do I move the trackball out of the middle of the selected door and adapt it on the hinge?
Or how do I define axis along the hinges to move the selected door of the filter casing?
Of course I know about the solution in using the trackball in front/top/right orientation, but I am sure, there is a smarter
function in CreoIllustrate.
An example is shown in the attached video: how to turn the safety clip in CreoIllustrate?
thx -bye
8 REPLIES 8
Peter,
When transforming (move or rotate) in Creo Illustrate you can Right-Click and choose Location to change the Coordinate System temporarily for the transformation operation.
See attached video.
Tim
Video Link : 2396
Hello Tim,
thank you very much - that was exactly what I have been looking for (*happy* now to carry on) 🙂
It would be great if video like this were available on the LearningExchange website : http://learningexchange.ptc.com/
Hi Vladimir,
We have addressed your request to the right contact person within PTC.
Regine
Hello Regine,
Thank you. I already asked this question a half year ago, here: http://communities.ptc.com/message/165963#166556
this video only takes me to the ptc community home page
Essentially what the video shows you is the ability to change the csys for a part.
This allows you to choose the csys of another part (for example the hinge) so that the door would rotate around the hinge.  You can also select an axis of a part if you need to be more specific.
Hope that helps.
Groovy!
