include C3DI File when copying an Assembly
Ronan
Hi all,
when processing a save as of a creo parametric assembly in whindchill, I would like to include the illustration work.
Unfortunately creo illustrate file is not embedded.
what is your workarround whith for this use case?
Mine is to save in local the c3di, break the link to the source, reconnect windchill and reconnect to the new published PVZ...
Catalina
Moderator
(To:Ronan)
Hi @Ronan,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
