The "Capture Location" and/or "Restore Location" function is broken in Creo View at least up to version 8.0. Just lost an hour of work moving parts and saving their position using "Capture Selected".
Then I was going to reset the position of those parts to the original position using "Restore Selected To Original". Instead, however, the parts' position was reset to the captured position that I had moved them to previously, and the original position was entirely lost, for every single Viewable and Annotation set of the assembly/file.
Thus, this feature is broken because "Restore to Original" erroneously restores not the original position, but the last captured position of the respective parts.
This should of course only happen if you select "Restore to Saved" and not "Restore to Original" 😤
@ptc, please fix this urgently.
Have you reported this to tech support? "Open a Support Case": https://support.ptc.com/apps/cs_loggers/case_logger/auth/ssl/log
Thanks Vladimir. Unfortunately I can't do that at the moment because I don't have a support contract with PTC, or rather, I don't know its credentials which are with my employer.
I will open a support case as soon as I get hold of the data of the support contract.
The IT administrator in your company should help with this.
You must be joking Vladimir?
The IT administrator in my company would not even know about 99.7% of the features of Creo View, let alone how to fix a feature that is broken in the software itself.
I mean, he has access to both the program's license file and the company's account on the PTC website.
Ah yes, of course
