[ABUSE] By: Anautics / Board: PTCAcademicProgram (5990)
VladimirN
Please move this question in Creo area: https://community.ptc.com/t5/Additional-Creo-Questions/bd-p/OtherCreoTopics
Link to post: (What beam type is used in Simulate?)
by Anautics
https://community.ptc.com/t5/PTC-Academic-Program-Discussions/What-beam-type-is-used-in-Simulate/m-p/348364#M5990
<body><p>Are the beam elements created by the beam idealization in Simulate: Euler or Timoshenko beam elements? </p><p></p><p>From <a href="http://support.ptc.com/help//creo_hc/creo30_sim_hc/usascii/index.html#page/sim/simulate/modstr/elements/reference/beam_el.html" title="http://support.ptc.com/help//creo_hc/creo30_sim_hc/usascii/index.html#page/sim/simulate/modstr/elements/reference/beam_el.html">PTC Creo Direct 4.0 Help Center</a>, the recommendation on beam aspect ratio suggests Euler beam elements are used? If so, is there any way I can change the beam type to Timoshenko? Or is the only option to do a solid mesh?</p><p></p><p>Thank you.</p></body>
This message has 0 replies
0 REPLIES 0
