AW: RE: SUMMARY: Hole vs Extruded Cut - Any strong preferences?
ptc-10292
2-Guest
o.k., it's a late response, but I think, it's important too.
If you are using Mechanica you can run into trouble with the automatic split
of a cylinder in 2 patches (2 x 180 deg). You are sometimes in the need,
that this half's have the same position, especially for contact analysis.
You can only control this by cut (divide the circle).
HIH Uwe
-----Ursprüngliche Nachricht-----
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
