I have a cantilever composed of a rectangular tube made of Alu into which is inserted a Steel U to strengthen it.
There are no games between the two parts.
The 5 faces in contact are defined manually with infinite friction.
But in the final result the two parts do not remain in contact, there is displacement through the matter.
What more should be proposed for contact?
Cordially.
Denis
Hi Denis,
Do you have the press fit control turned on in your analysis?
Silulate sometimes does not like line to line components and sometimes ignores the contacts.
Another option is to cut back the outer surface of the internal part so there's a very small air gap between the 2 parts so the contacts are invoked.
Hope this helps,
Don Anderson
Hello Danderson-3,
The part between iron, between the two parts is zero,
I do not understand this control:
Do you have control of the pressure adjustment activated in your analysis?
Contact surfaces are defined manually (not automatically)
Cordially.
Denis
Hi Denis,
Verify that you have press fit enabled within your analysis to ensure the contacts are are processed for the line to line surfaces.
Don
Denis,
You may also want to verify that you are displaying the results 1 to 1.
If you scale up the deformation for the display of the results the system may be exaggerating or displaying interface/result.
Don
Hello Dandorson,
Thank you for this information, I'll take it back in a moment.
I would keep you informed of the results.
Yes, if we increase the scale of the results there are exaggerated deformations.
Cordially.
Denis
Hello Danderson,
I had filled the page for the contactes.
See the attached page.
Cordially.
Denis
Hi Denis,
I would set the value for the press fit control to 0.5 or something just over zero.
This will make sure all of the outer surfaces of the internal part are pulled inside the outer component and allow the contacts to be fully processed.
Don
Hello Danderson,
I just redo the simulation with the 0.5 mm and it has not changed anything, it's exactly the same picture.
Cordially.
Denis
Hi Denis,
Verify the displacement result's are being displayed at 1:1 ratio?
Would your load being applied be high enough to shear/displace the alumuinum where the load being applied?
Don
Thank you for this very complete example.
This is pretty much what I had done, but blocking the two pieces on one side and loading the two pieces on the other.
Now why the springs, two in the front and one in the back, I had never done that.
Why this BLANK material in assembly?
Sorry to ask you these questions but this way of doing things is new to me and very interesting.
Cordially.
Denis.
Hi Denis,
The springs have a down side as they may add a singularity and they do add additional calculations to the analysis.
They were added to stabilize the component with no bonded constraints or displacement constraints who's location was controlled by contacts. The blank material was just a place holder that I forgot to remove from the assembly.
Don
