Assembly - Interchange
mfrels-2
Interchange in WF4 from WF3 seems to be quite different now. I cannot find the Auto Tag function that I was especially used to in WF3 and earlier. Has it been deleted or just moved to someplace I have not found yet.
Kevin
(To:mfrels-2)
It's accessed under the reference pairing table. To get to it there is an icon on the toolbar (looks like a table with a column highlighted) or select Insert>Ref Pairing Table. I haven't I created an interchange assembly in WF4 so I can't guide you through the process. There is a section under the Help Assembly Design>Assembly>Using Assembly>Working with Assembly Components>Interchange Assemblies>To Pair Reference Tags Automatically.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
