Hi all,
when do you use limits for creating and editing mesh?
Are there any particular circumstances? And which values do you adopt?
Shell? Tetra/solids?
Bye
You suggest absolute tolerances therefore you separate from the "box dimensions" of the entire assembly. Right?
yes, and more
materials, AutoGEM-Settings ...
Yes I saw.
Usually, when I use shell elements, I set:
