AutoGEM Settings
gfraulini
AutoGEM Settings
Hi all,
when do you use limits for creating and editing mesh?
Are there any particular circumstances? And which values do you adopt?
Shell? Tetra/solids?
Bye
skunks
(To:gfraulini)
tested settings
gfraulini
(To:skunks)
You suggest absolute tolerances therefore you separate from the "box dimensions" of the entire assembly. Right?
skunks
(To:gfraulini)
yes, and more
materials, AutoGEM-Settings ...
gfraulini
(To:skunks)
Yes I saw.
Usually, when I use shell elements, I set:
  • edge max/min 165/15
  • face max/min 165/15
  • max asp ratio 8
  • max edge turn 75
