Bevel (differential pinion and crown) Gear Design – Non‑Coplanar Offset for Enhanced Contact
PK_13333740
3-Newcomer
Hi all,
I'm working in Creo Parametric Mechanism to model a pinion and crown gear assembly with axial/radial offset between their axes.
This is not a standard intersecting-bevel gear setup — the pinion and crown gear must mesh with a deliberate offset between their axes.
However, when I attempt to apply the built-in Bevel Gear Connection, Creo throws: "The references for bevel gear connection are not coplanar”.
How can I simulate bevel gear kinematics when the pinion and crown gears are offset (i.e., non-coplanar axes)?
Hi @PK_13333740,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
In the case of regular Bevel Gearing, the axes of the cone angles are co-planar. These being spiral bevel gear, perhaps a Virtual Cone angle may be present that makes them co-planar. I guess, one may have to try that route. Just a hunch.
Srinivasan Iyer
