CREO FLOW ANALYSIS PARTICLE
TE_10845341
Dears,
I have little experience with PTC software, especially with CREO FLOW ANALYSIS. Would it be possible to clarify a question I have?
I need to carry out an analysis of a fertilizer distributor using DEM technology, similar to the one demonstrated in the video available at the following link: https://www.youtube.com/watch?v=dj_51S7k_sM. Is it possible to carry out this analysis using the "CREO FLOW ANALYSIS" tools?
Thank you in advance for your attention.
Sincerely,
Tales Eduardo Zorzenon
tmoser
(To:TE_10845341)
I've never done an analysis like what is shown in the video. My first impression is that this beyond what CFA is meant for. It is possible to introduce particles into a fluid domain and track their movement within that domain. What is shown in the video would involve interaction between the particles and the spinning solid domains, and then between the particles and the fluid domain (air).
Maybe one of the experts from PTC could offer their insight too.
tmoser
(To:TE_10845341)
TE_10845341
(To:tmoser)
Obrigado pela sua resposta.
Atualmente estou estudando a ferramenta CFA Particles, porém, tenho encontrado dificuldades na execução da análise. Não tenho certeza se esta ferramenta é capaz de realizar o tipo específico de análise que necessito.
cfdgeek
(To:TE_10845341)
Hi Creo flow can defiantly solve this problem. It has particles model and can model particle with rotating domain very easily. saw a lot of similar simulations from current customers. If you need help please talk to PTC support. thanks.
