CREO FLOW simple spray bar /water manifold
David_Hale_00
Is anyone kind of enough to help me model and share the file of a simple water spray bar, (straight pipe with holes) and apply a volumetric flux on the inlet and maybe 2 outlets atm pressure?
I want to try and model and assess the geometry on the spray trajectories? is that possible?
CREO 10 premium edition
cfdgeek
(To:David_Hale_00)
Hi you need to use multiphase and model the whole external domain including the pipes. Please try watch tutorials for external problems or you can contact ptc support. Thanks.
