We’re aware that the eSupport site is currently down, preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
I am using Creo Simulate Release 6.0 and Datecode 6.0.6.0
CREO SIMULATE NOT GENERATING BONDED SURFACE VIA THE WELD CONNECTION TOOL
SIMULATION FAILS BECUASE IT IS NOT PROPERLY CONSTRAINED
See attached file for visual of problem
Update: changing the weld size from .25 to .5 has cause the weld to bond correctly (both surfaces bonded). But still have problem with smaller weld size. Software problem or user problem?
