CREO2 : Reference plane in drawing
ldrutel
I use Creo2. When i put a view in drawing, automatically the references planes appear.
1) Is it possible to desactivate this function ?
2) Is it possible to select all the references planes in the sheet or in a view to suppress them ?
ldrutel
(To:ldrutel)
I have found the solution for my second question.
Select the references plane in the specifical view in the drawing tree
kdirth
(To:ldrutel)
This is what the layer tree is for.  Make sure the planes are in a layer in the model and hide the layer in the drawing.
mbonka
(To:ldrutel)
1.1) Try to set your config option display_planes to NO. ---> it hides datum planes when Creo is started
1.2) Put planes in a layer and hide them in your template drw.
1.3) Put planes in a layer and hide them in individual drawings.
Regards
Milan
