Calculate true stress in notches
skunks
here is an example
5 REPLIES 5
Catalina
Moderator
(To:skunks)
Hi @skunks
I recommend giving more details and context in the body of your post about the problem you have in mind. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Catalina
PTC Community Moderator
PTC
KenFarley
(To:Catalina)
I don't think this was a question in need of an answer. The contents of the attachment are an analysis of the proposed problem as well as, I suspect, a model with the proper FEM analysis setup. Maybe it was  a mispost, intended as an answer to another question on the forums?
skunks
(To:Catalina)
Sorry for the misunderstanding, it was a recommendation for the conversion of the notch stresses, not a question 😂
rrabe
(To:skunks)
Hi @skunks , I have noticed that the moderators are having difficulty identifying the purpose of your posts - maybe their "algorithms" only understand "questions" and not "tips and tricks" or " homages" for example. I suggest that you start these types of posts with "This is not a question". 😁
skunks
(To:rrabe)
😁 a good idea
