I am using Creo Parametric Release 5.0 and Datecode5.0.5.0
The issue is that when we attempt to run a Flow Analysis we get the following error message: “The selected functionality requires Creo Flow Analysis license.” We are running Creo 5.0.5.0. with Creo Design Advanced Plus.
When searching the error message, you will find this article ; https://www.ptc.com/en/support/article/cs277387
Was it of some help?
Do you have a license for Creo Flow Analysis?
If so, you should contact the VAR that sold you the licenses and ask them the correct method of using them. It's likely something not being set up properly when you installed Creo.
I would still get with your VAR and make sure (that things were set up properly for Flow Analysis) when Creo was first set up. Sometimes the ancillary programs may not have be properly set up when you got to use them even though you have been using Creo for a long time.
