Hello all,
Here is my problem, I trying to simulate a chair arm being loading horizontally (from the center of the chair out). The Arm consists of a steel insert which is attached to the lower arm which connects to the bottom of the seat. Suffice to say the lower arm is quite stiff and will not deflect much. Therefore the insert should behave like a cantilever beam problem. The insert is a 1/2" diameter 6" length rod (exposed length) that is made of 1010 cold drawn steel (what I have been told). From hand calculations and using the ultimate stress value for the material, the insert should fail at around 100lbf, however in a physical test it goes well beyond that (been tested at 250lbf) and did not plastically deform or very little. I initially ran the static problem in mechanica and the deflection was so small that I didn't run it as a large deformation analysis, and the stresses evident in the rod were well above yield and ultimate. So my question is, is there something obvious I'm missing in my analysis or my theory.
Any help would be appreciated.
Al
