Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Is there a config option to have leaders from chamfers to be able to rotate 360°, instead of be dragged at the angle? Using WF3.0 M210.
I believe I use to be able to rotate the leader around the chamfer
Rick LyBarger Jr.
Husky Corp.
Pacific, Mo 63069
This electronic mail message contains information that (a) is or may be LEGALLY PRIVILEGED,CONFIDENTIAL,PROPRIETARY IN NATURE, OR OTHERWISE PROTECTED BY LAW FROM DISCLOSURE, and (b)is intended only for the use of the Addressee(s) named herein. If you are not the intended recipient, you are hereby notified that reading, using, copying, or distributing any part of this message is strictly prohibited. If you have received this electronic mail message in error, please contact us immediately at (800) 325-3558 and delete the message completely from your computer system. Thank you
This email has been scanned by the MessageLabs Email Security System. For more information please visit This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
