Co-axial holes
StevenDunell
Co-axial holes
In WF3 you could place a tapped or drilled hole in an assembly using the
co-axial command. Has this function be changed in WF4??
I can't seem to find the option.
TIA
CBenner
(To:StevenDunell)
I was able to do this, though the option doesn't show up directly. Select the hole command, and then pick an axis, it will default to the coaxial hole and prompt for a reference surface.
Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u>www.powellfab.com
P: 989-681-2158
F: 989-681-5013
</u>
Chris Benner
Autodesk ® Expert Elite
CBenner
(To:StevenDunell)
My above post was meant to offer a solution to the original poster's question.
Chris Benner
Designer II
P: 989-681-2158
F: 989-681-5013
</u>
Chris Benner
