Creao Animation real time duration
gfraulini
Goodmorning to everyone,
I use Creo 8.0.9.0 and I'm wondering how to create an animation based on a MDO analisys that has the "real time duration".
If I set the time.duration of 10 seconds, I expect this duration will be respected when I make the video exportation; all of this means the mechanism has the real velocity.
If the mechanism is simple,  more or less the duration/velocity is respected; if the animation is a bit complicated, the "post-production" video will be longher.
Is there the possibility to impose the video exportation duration?
Chris3
(To:gfraulini)
I have only used the animation module (not sure if you are doing the same) and it has been a while, but there is a setting for FPS or frames per second during the export.
There is a rate setting in the time domain
If your "rate" is not equal to your FPS then there is going to be a multiplication factor of rate/FPS applied to your time length you have specified.
Chris3
(To:gfraulini)
