I have an issue with Large Deformation Analysis : my simulation involves two parts with snap fits (I have defined contacts between the surfaces that will have to interact). The problem is that when I try to launch a Large Deformation Analysis the program crashes and the CREO window disappears. On the contraty, when I launched the LDA for a snap fit problem involving two very simplified bodies, no problems occurred.
Thank you very much for the help.
Best Regards
Have you verified that materials have been assigned to all components and the materials have valid properties?
Do you get any error messages when you Autogem mesh the assembly manually before running the analysis?
Don
yes I have already checked and no error message appears when I mesh the components. The simualtion runs without problem if I do not set LDA (but of course results are wrong).
Thank you very much
After re-reading your issue. It might be related to how you have some of your contacts defined.
Have you tried applying the contacts as one contact part to part and leting Creo auto define the contacts?
Hope this helps,
Don
Unfortunatelly I had tried also this solution but without success. However thank you very much for the help, if I undestrand what was wrong I'll let you know!
Claudia
Do you have any springs defined or shell elements in your analysis that you are trying to run?
Hi!
No, I have no springs and no shell elements, just two components meshed with solid tethra elements.
Thank you!
Regards
