Creo 3.0 M140 - Reverse Mouse Wheel Not Working (Win 10)
My mouse wheel works like this:
Roll the Top of Mouse Wheel Towards the Front of the Mouse -> Zoom OUT
I have added the use_inverted_mousewheel_zoom Yes to my CONFIG.PRO
No matter if the setting is Yes or No the mouse wheel zoom
function is exactly the same.
I want the mouse wheel to Zoom In when the mouse wheel is rolled
towards the front of the mouse.
Any suggestions?
I tested use_inverted_mousewheel_zoom YES in CR3 M110 and M150. It works well in both versions.
IMPORTANT: You have to put the option into config.pro and restart Creo !
I did have it saved into my CONFIG.PRO file...
I feel stupid but I did not know that you had to restart Creo. 😕
I restarted and it IS working now.
None of the posts regarding reversing the mouse wheel mentioned restarting Creo...
THAT was the missing piece to my puzzle!
Thank you!!
Please mark Martin's answer as correct for those who may search on this topic so they know that you found a solution.
REMEMBER!
It's RESTARTING Creo that was the missing key (after editing the config.pro)
