Creo 7 vs Creo 10 Buckling Results
Beuk
Hello fellow engineers,
Recently I updated from Creo 7.0 to Creo 10.0. I am in the middle of a project so maybe it wasn't a good idea. When re-running a buckling analysis that used to return a BLF of about 2.5 in Creo 7.0, now I get values of about 0.5!
Has anyone noticed this pattern? I believe the new 10.0 version is overconservative, as I have done hand-calculations to verify the buckling mode and the plates are nowhere close to buckle.
I believe the solver must have been updated. The model in question corresponds to a crane with a telescopic boom, where the contact pads (usually solids to allow for contact definition, non-linear analysis) are replaced by a beams (linear analysis).
Catalina
Moderator
(To:Beuk)
Hi @Beuk
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Beuk
(To:Catalina)
Thank you @Catalina,
Lets wait and see.
