Hi Dave,
The issue got resolved in Creo 9.0.1.0. There was a problem in the previous versions of Creo Ansys Simulation.
Niloy
The error message is attached.
Opened C15883128
For solution refer to article: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS344735
A SPR has been filed as the error has been replicated by PTC tech support. So now we need to wait for them to figure out the cause of the error.
That link no longer works.
Hi Dave,
Niloy
I got it also in Creo 9.0.4.0
That could be some other problem as the specific problem that I had faced in Creo 8 was finally resolved in Creo 9.0.1.0.
Niloy
