Creo Ansys Simulations fails to complete an analysis
NiloyGuha
7-Bedrock
I am using Creo Parametric 8.0 8.0.0.0
Analysis fails after mesh is created and 99% of the FEA is completed of a fairly complex assembly. The same assembly has been successfully analysed in Creo Simulate.
Hi Dave,
The issue got resolved in Creo 9.0.1.0. There was a problem in the previous versions of Creo Ansys Simulation.
Niloy
8 REPLIES 8
The error message is attached.
Opened C15883128
A SPR has been filed as the error has been replicated by PTC tech support. So now we need to wait for them to figure out the cause of the error.
That link no longer works.
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
Hi Dave,
Niloy
I got it also in Creo 9.0.4.0
That could be some other problem as the specific problem that I had faced in Creo 8 was finally resolved in Creo 9.0.1.0.
Niloy
